Note 5 Notification Bar Color Change Today. Help
roll2tide
10
ATT Galaxy Note 5
Stock Android 6.0.1
Nova Launcher Pro
Samsung Store theme
So this morning I updated 2 Samsung apps per a push notification. One was Touch of Style and I don't know the other. I give the ok to update and head off to the shower. When I come back, my notification bar is purple. I have a couple of different themes from the Samsung Store and I have applied several but this color doesn't change. I do not see a setting with Nova to change this nor do I see one in system settings.
Thoughts?
roll2tide
10
Thank you. That thread does leave out some info that I figured out.
The app: Good Lock
To access it: Bring down the notification bar and then press and hold on the top of the bar. Tap the icon that looks like a painters palette.
The colors can be adjusted and this is actually a very cool little app once you get it matching your screen.
Google Good Lock for how-tos and features.
lizardchest
584
Well done! I've copied your post to the other thread so others can see your findings. Cheers!
shirlysmith44
