[Q] Asus MeMoPad HD 7 ME173x Authentication problems when connecting to wifi?
wivane
Hello AndroidCentral,
I am having some issues with 2 Asus MeMoPad HD 7's. The problem being that when I try to connect to WiFi i constantly get back "Authentication problems". I have 58 other Memopads that are connecting to the same WiFi just fine however these 2 pads keep giving me the same authentication errors. I have tried taking off the wireless password and they still do not connect. I also have tried connecting it to my phones Wireless Hotspot which works perfectly fine. Does anyone have any ideas as to what i can do to connect these 2 Memopads to the wifi.
Things i have tried:
Connecting to a wireless hotspot
Removing the password to the wireless
Flashed the memopad with a stock ROM
Factory reset the device
wiped the cache
wiped the dalvik cache
made sure i entered the correct wireless password
Is there anything else i can try?
Thanks,
Wivane
Edit: Sorry if this is in the wrong section, if it is can it be moved to the correct section by a moderator.
Edit 2: Please check out this thread on XDA Developers also. forum. xda-developers. com/memo-pad-7/help/asus-memopad-hd-7-me173x-authentication-t3056323#post59497688 Cannot post links due to not having 10 posts!
wivane
Bumping for any help? Is anyone out there able to help me with this?
UPDATE FROM XDA:
Quote:
Originally Posted by muiriddin
You aren't running out of IP addresses being assigned are you? DHCP having X number of addresses in the pool and the problem memo pads being X+1 and X+2?
No, we havent run out of IP Addresses. We also tried to assign a static IP Address outside of the DHCP range and that didnt make any difference. Would you know of any other things we can try?
So there is a quick update and this is another request for help! We havent run out of IP Addresses and assigning a static IP Address does not help in the slightest.
Thanks for reading,
Wivane
cottoneyejoe
