[ROM - 6/4] - CleanROM 2.4.5 SE -★| Landscape! | EQS! | APM! |★-
snoopgoat
Active member
Apr 8, 2012
40
3
Re: [ROM - 6/4] - CleanROM 2.4.5 SE -★| Landscape! | EQS! | APM!
Just flashed the clean rom. Nice Job.
I have one request for future updates. Could you re-re-map the hardware buttons so that the recent apps button pulls up the recent apps (normal ics behavior), and then a long press on the recent apps button maps to the menu button?
My reasoning, is eventually, the "menu" button is something that will get obsoleted, so mapping it as a secondary action (i.e. long press) is a better approach. Or, you can give a setting where users have a choice. I dunno. Personally, I'm not a fan of long-presses, so I prefer it for functions I hardly use (like menu).
While you're at it, you could shove in s-voice, and have a long-press on the home button launch s-voice. no? :)
rejovinated
9
They do provide you to remap the buttons back to normal in the cleanrom folder. You just have to flash it. There's also the battery % mod and WiFi hotspot hack in the folder.
Sent from my HTC One X using Android Central Forums
rdxhd
154
20
is multitasking improved in this rom?
neocryte
201
5
I am using CleanROM 3 Lite, and I have to say I am very impressed. It is very smooth and stable, and I have yet to find anything that does not work.
Unfortunately, it does not fix my battery issue (LTE + signal loss leads to huge drains after signal is regained), I think I may have to try a Sense-free ROM for that.
But again - awesome job on CleanROM, I love it!!
lilliejoylene
