[ROM][GB][WIP] CyanMobile Experience for the OV
thewraith420
1,987
223
63
@thewraith420, how much input and influence did you have in this build?
Sent from my G6
Not sure what you mean? This is sellers project, I just really like it :D
Edit:also if you
1. flash rom
2. flash gapps
3. enable mount sd-ext in development menu
4. hit home
5. return to dev menu and enable the other 2 sd-ext options
6. enable and setup wifi
You should have working sd-ext and wifi but it won't enable alternate keyboards.
sellers86
1,837
617
Great rom, slapped full of goodies . By far the best. I would like to know how to get the app2sd-ext to run and hold. Prefer not to use link2sd.(obvious reasons)
@sellers86, awesome piece of ov art. Thanks for your hard work and can't wait for your future builds.
Sent from my G6
As he stated, he had no influence on this build, though he has tried to build it from source :)
Sent from my One V using Android Central Forums
thewraith420
1,987
223
63
I've tried... Unsuccessfully I might add. I still might try again some time but for now it's on hold due to hunting season :D
jAdOg@88
59
@thewraith420, big help as always. Thanks :thumbup:
@sellers86, I'm sure the next build might have his name mixed in with yours.:eek:
Jk :D, thanks again for the party favors.
jAdOg@88
59
Just to add, it allowed me to change keyboards, (slideit) just had to reboot halfway through setup. Rom is awesome, :thumbup:
thewraith420
1,987
223
63
So your sd-ext, wifi, and alternate keyboard are all working? The closest I got was sd-ext+keyboard or sd-ext+wifi never all 3
Tapatalk'n it from my VM670 running OM-Mandylion IHO on LS670ZVJ baseband
jAdOg@88
59
Yes, however seems unbalanced somehow. Like something in the framework arguing. Idk, will have to reboot every time I go from wifi to data.:confused:
sellers86
1,837
617
If one of you could get me a logcat, I'd appreciate it.
thewraith420
1,987
223
63
Not running it currently but I might flash over and see what I can get you
jAdOg@88
59
I got logcat in my email if you would pm me your e-address. Looks like the sd-ext doesn't truly link through data/app. In my root explorer, normally shows in data/app, the extended size from the link. In this case, it shows no size at all when opening the data/app folder. It will show the internal space in data(179MB), not data/app(no space identified) . All this is when the sd-ext settings enabled.
To apply Wi-Fi, alternate keyboard, and sd-ext, I did it in this order:
*apply Wi-Fi and reboot
*install alternate keyboard and power off
*pull battery for 30 seconds and power on
*finish keyboard install/reinstall if it didn't automatically and reboot
*power off/pull battery
*power on and go to development
*enable sd-ext, (the other 2 settings should go active and ready to enable)
*reboot
Google play store may disappear and lockscreen might not work after applying. I had to reinstall playstore from system/app, not sure why it disappeared.
jAdOg@88
59
Wiped/Flashed this rom numerous times. In each of those times, the terminal emulator would not toggle the soft keyboard. Ended up deleting it and installing one from playstore. Then after toggle, start typing, it would bring up Google search:confused:
Bizarre... anyway I would start new window and was able to access logcat.:D
jAdOg@88
59
Love the rom sellers, I'm just a tester/user. I know you are a busy dev. I will keep testing and tweaking.
Sent from my VM670 using Tapatalk 2
sellers86
1,837
617
Hey Sellers, is wifi tethering working? I tried the native one and it wasn't connecting, but it showed up... ?
Yes. I used it multiple times when mediacom decided to shut down our WiFi (and almost everyones in town, it happens all too often). That's one thing I'm sure of.
rezaking886
