[ROM][ICS] the GODZILLA ROM 10-20-12
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Johnny since the bass beats I think it lowered sound on plugged in speakers headset cause I can't make it louder with custom dsp settings:(
Sent from my LG-VM670 using Xparent Pink Tapatalk 2
Thats weird not for me I will test now
EDIT: NO PROBS HERE
Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
Reactions: ganggreen30
ganggreen30
190
3
Ok was thinking about it
Who doesn't like the translucent status bar?
If enough people don't like I will remove
Don't remove it just give an option to change it like jerryscript did in his backside iho Rom that's the awesome sh!+ right there
ThatGuyLurkin
2,155
665
Your asking for alot. That was IHO gingerbread, not Android 4.0 Alpha/Beta.
and an option for a transparent dropdown notification background would be sweet!... :)
ganggreen30
190
3
DUDE I still can't get my dsp to increase my volume using custom on an external plug in speaker wtf . Last thing I want to do is a full wipe and reinstall.
ThatGuyLurkin
2,155
665
Yes I was thinking about that would have to use bobzhome cuz its his base
Because its a base, doesn't mean it wont worK. ;P
I use Framework/SystemUI from all kind of devices depending on the features.
But that's a simple fix. Make a flashable zip to get a solid status bar.
Souns problems could come from the beats though. I say make a version without it, and let people test to see if they have sound problems
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Re: [ROM][ICS] THE GODZILLA ROM tweaked and themed cm9!!!!!!!
will do tommorow cuz im sooooo close to fixing themes in miuigb
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
If my testers are reading this you will receive a test build today/tommorow
Your job is too test the difference between the sound quality and see if dsp works
Sent from my LS670 using Android Central Forums
leeroy4000
6
I'm still having trouble with voice search I tried:
Message By dosangst
"I was able to fix voice search by using super manager and removing the a p k from the system folder and then reinstalling it from the market..."
But it said it wasn't uninstalled. Any ideas? Thanks for taking this on, look forward to seeing where it goes! Good luck.
Dcoolest01
