[rom][sero7 pro][gummy][unofficial][kang]
bdadd34
10
KANG######THIS ROM IS UNOFFICIAL######KANG
I've been builing this for a while now for personal use and I thought I would share it now that everything seems to be working. All I do is compile and upload..these are the Devs that did all the tough stuff...Thanks for making this such a great Tablet.
All Credit, Thanks & Donations need to go to these guys:
TEAM-GUMMY- https://twitter.com/TeamGummyRom
randomblame- TakTik Rom
delorespark- DOPA Rom
davepmer- CM-11
USE AT YOUR OWN RISK !!!!!!!
NOT MY FAULT IF YOU BRICK YOUR TABLET!!!!!
YADA YADA YADA!!!!
Git Hub----kernel https://github.com/bdadd34/android_kernel_hisense_m470bsa
Download GummYKanG--
3-13-14- new kernel with no oc based off of delorespark kernel source with davepmer wi-fi + full device tree including ramdisk..all deloresparks original patches for audio and charger. It doesn't have his latest bluetooth patch but i will add into next build. i will upload an oc kernel in post #2 shortly for those wanting one. Dont know about adding govs...they seem to lag pretty bad and i have yet to find any in other tegra 3 device. I'm thinking there is reason for that...so instead i will try to tweek interactive and ondemand and see how that runs.
3-29-14- new build based off delores park aosp repos and all his patches except 2nd a2dp patch which caused problems with viper4android and some bluetooth audio freeze ups. I will start weekly updates now and sometimes sooner if needed. No overclock in rom but I will upload a new basic oc kernel tomorrow.
gUmmYkAng dOwnlOAd fOldEr
Download your favorite 4.4.2 gapps-
PA Gapps [GAPPS][4.4.x/4.3.x] OFFICIAL 0-Day PA-GOOGLE APPS (All ROM's) [2014-03-29] - xda-developers
Slim Gapps http://www.slimroms.net/.../addons4-4
highly recommended
Download SuperSU SuperSU Download
Boot to recovery--use one of randomblames recoveries either one should work fine.
wipe data and format system
flash rom
flash gapps
flash superSU
Enjoy
Screen Shots
jdremler
3
just installed this Rom wifi is a little screwy. Had to random reboot and then I couldn't turn the wifi on and had to reboot it again to get the wifi to come on. Other than that so far everything seems to work HDMI works very well better than with the stock rom. Vudu work like **** on stock rom using my HDMI and worked awesome with this ROM and I haven't really found any other issues than the wifi.
Chamberfis6
Installed Gummy a few days ago and I am really pleased. Great look, features, etc. I've had multiple problems with tiktak and not one problem with this ROM--heck even the sounds work.
thanks.
