Hi,
I have a Samsung Galaxy Y Duos phone running Gingerbread 2.3.6.
I tried rooting the phone using the root kit in [Root Locked Bloader]Nexus One Easy Rooting Toolkit (DoomLord's via Zergrush Exploit) - xda-developers and am seeing the fwg error messages. Appreciate any help on resolving this!
Easy rooting toolkit (v4.0)
created by DooMLoRD
using exploit zergRush (Revolutionary Team)
Credits go to all those involved in making this possible!
[*] This script will:
(1) root ur device using latest zergRush exploit (21 Nov)
(2) install Busybox (1.18.4)
(3) install SU files (binary: 3.0.3 and apk: 3.0.6)
(4) some checks for free space, tmp directory
(will remove Google Maps if required)
[*] Before u begin:
(1) make sure u have installed adb drivers for ur device
(2) enable "USB DEBUGGING"
from (Menu\Settings\Applications\Development)
(3) enable "UNKNOWN SOURCES"
from (Menu\Settings\Applications)
(4) [OPTIONAL] increase screen timeout to 10 minutes
(5) connect USB cable to PHONE and then connect to PC
(6) skip "PC Companion Software" prompt on device
CONFIRM ALL THE ABOVE THEN
Press any key to continue . . .
--- STARTING ----
--- WAITING FOR DEVICE
* daemon not running. starting it now *
* daemon started successfully *
--- creating temporary directory
mkdir failed for tmp, File exists
--- cleaning
rm failed for *, No such file or directory
--- pushing zergRush
441 KB/s (23060 bytes in 0.051s)
--- correcting permissions
--- executing zergRush
[**] Zerg rush - Android 2.2/2.3 local root
[**] (C) 2011 Revolutionary. All rights reserved.
[**] Parts of code from Gingerbreak, (C) 2010-2011 The Android Exploid Crew.
[+] Found a GingerBread ! 0x00000118
[+] Found a Samsung, running Samsung mode
[*] Scooting ...
[*] Sleeping a bit (~40s)...
[*] Waking !
[*] Sending 149 zerglings ...
[*] Waking !
[*] Sending 189 zerglings ...
[-] Hellions with BLUE flames !
--- WAITING FOR DEVICE TO RECONNECT
if it gets stuck over here for a long time then try:
disconnect usb cable and reconnect it
toggle "USB DEBUGGING" (first disable it then enable it)
--- DEVICE FOUND
--- pushing busybox
3270 KB/s (1075144 bytes in 0.321s)
--- remounting /system
mount: permission denied (are you root?)
--- checking free space on /system
107 KB/s (439 bytes in 0.004s)
df: /mnt/.lfs: Function not implemented
--- Free space on /system : 21092 bytes
--- no cleanup required
--- copying busybox to /system/xbin/
/system/xbin/busybox: cannot open for write: Read-only file system
--- correcting ownership
Unable to chmod /system/xbin/busybox: No such file or directory
--- installing busybox
/system/xbin/busybox: not found
--- pushing SU binary
failed to copy 'files\su' to '/system/bin/su': Read-only file system
Unable to chmod /system/bin/su: No such file or directory
--- correcting symlinks
rm failed for /system/xbin/su, Read-only file system
link failed Read-only file system
--- pushing Superuser app
failed to copy 'files\Superuser.apk' to '/system/app/./Superuser.apk': Read-only file system
--- cleaning
--- rebooting
ALL DONE!!!
Thanks for any suggestions.
SG
created by DooMLoRD
[*] Before u begin:
--- STARTING ----
--- cleaning
[*] Scooting ...
[*] Waking !
[*] Waking !
--- DEVICE FOUND
--- pushing busybox
--- cleaning
--- rebooting
ALL DONE!!!
SG
