Serious Problem HELP PLEASE
Makaveli1490
61
When it boots it stops at thunderbolt screen, it freezes
Im tried to boot into recovery from h-boot but the phone automatically goes into h-boot because I have the GB radio on there
I cant get to recovery
ssethv
ANDROID OBSESSED
Dec 4, 2010
1,582
371
actually take the SD card out of your phone and put it into your computer with an adapter, then switch back to your original radio that you started with ... remove the PB05IMG first and the then put the old radio PB05IMG back onto the card... put it into the phone turn on into HBOOT mode and that should do it. then revert back to your most recent nandroid backup and start over doing what ever you were trying to do... Just keep a library of your radios and what they are for... here is a link to all of them.... pre RUU, current OTA RUU and GB radio's [RADIO] The Obligatory Thunderbolt Radio Thread - xda-developers
Reactions: zero neck
Comineeyeaha
679
56
If you have an sd card reader, take the sd card out of your phone and delete it on the computer. If not, plug it in to another old phone and delete it there.
Makaveli1490
61
Thats crazy h-boot don't even give you an option to choose what you want to do if the radio file is on the sd card
It first booted up, but the next time it tried it was stuck. So I did wipe data and all of that to get the start screen to remove the radio file
Makaveli1490
61
^ Long story... but it did boot the first time. I waited and when I tried to restart in recovery. It froze. So once I took the battery out, it stop booting correctly
I shoulda deleted the radio file soon as I got the chance
goodweather2024
