Sound with jack
emiinn
258
Do you guys notice a low sound when you plug in your phone with jack to a stereo or something?
Is that even fixable. I've a beast stereo when it's plugged in to my pc and on my phone I have to set the volume of the stereo to max to have a bit of noisy music..
All songs are good quality and amplified enough to play loudly
NOTE 3 - Tapatalk
dancing-bass
1,022
17
First thing - is it a low hum? does it change if you put your hand around the phone, or around the headphone jack on the phone while plugged in? have you tried a different cable? Also, instead of maxing the volume on the stereo, try turning that down and max out the volume on the phone first. Does that change anything?
emiinn
258
No its no low hum and I tried to reboot the phone. Can't try a different cable since it's build in.
NOTE 3 - Tapatalk
daves221
524
Are you plugged into a wall charger when listening? Try unplugging from the charger/power source and use battery only
