the tags system is driving me crazy...
Perseveranze
4
This problem started since last week and I just don't know why.
Every Samsung android s3 comes with a program called "tags version 1.2". The issue is, every time I make a call and move my phone, the tags screen comes on. So if I want to end the call, I have to first exit from the "tags system" and then I can go back to call screen.
Here's a picture;
Now I've tried to stop the program but that doesn't work. You can't uninstall "default apps" (on android)... So I don't know what to do.
Anyone know a solution to this?
funkylogik
9,637
111
Cant you disable it?
Do you have a NFC app installed?
Unbranded international s3 with Official JB. Paisley, Slotland, Western Europe :beer:
Perseveranze
4
I can't disable it, when I got to apps settings, the "disable" button is greyed out. It only has "Stop" (but then the program just ends up restarting).
As for NFC app.. I have;
NFC Service
NFC Test
And the settings for "File/data transfer - > NFC" is put to "On".
edit: Ok, that fixed the problem... it was the setting above, turned it off.
Thanks.
