what will I loose with nova
techie5
362
Hi Folks
Does anyone know if we loose all customizations with the UI if we use Nova? For example, if I choose one of the navigation bar settings with four functions, will it stay that way with Nova?
Thanks
techie5
362
Thanks. Did you try to change the navigation buttons with the LG UI and see if you loose them with Nova?
Thanks much
OhAlfie
872
11
18
Knock off will only work by knocking on the status bar. For me that was a neglible price to pay to have Nova.
There is an app you can download if I recall correctly that allows you to still use the knock off feature. You just have to activate it in the Nova settings.
Euan Tan
200
mainly the Knock knock but if you tap the Notification bar twice it still works... also I notice some of the widgets don't work while it works on the original launcher. Im not sure if its just me or its everyone though..
Abdul Ali
