78standards
Active member
So a couple of important questions - will I be able to get at least 64 gb of internal drive space? I need the room for applications. Secondly, will I be able to use the microSD card as additional internal drive space? I heard that Marshmallow allows you to expand your total drive space using your SD card. That will ensure that I can install the applications I normally utilizing. The one thing I hated about my previous 32 GB Note Edge was it only came with 32 GB of internal space. I constantly ran out of space.
..my understanding at this point is you will max at 32gb of internal storage with the SD card being secondary for the storage of photos, music, etc.
