I have a bunch of them.
Rob
Thanks. That means I have to get the accessory option with car charger. More Verizon $$$s.Considering the Note 3 has a different plug than the Note 2, I'm going to say no.
Can't speak for it all, but I believe it has been confirmed to work with most. Heck the note 3 even works with the note 1 desktop dock I have.the port on the bottom should work fine with the older USB 2 connectivity options from the older phones.
The USB 3 is basically a mini HDMI and a micro USB port lol
Sent from my GT-P3113 using AC Forums mobile app
NO, Samsung didn't say that. If you go to the Samsung website it shows the 3.0 port and says the 2.0 usb cables can still be used as it's backwards compatible. It just advices that charging via 2.0 will take longer.I don't feel safe using microUSB accessories with the 3.0 port. Have you put one in yet? It's loose and wiggles. That's dangerous in my mind using chips and an electric current.
Also samsung said using cables other than samsung 3.0 may cause your note 3 to blow up. Look it up.
Sent from Samsung Galaxy Note 3 now Free
Naw that is really what the mini USB 3.0 port looks like. Get a USB 3.0 external drive and it will look the same. The point is that the USB 3.0 port is actually backwards compatible with usb 2.0 so all usb 2 connected options should work. Only thing I am not sure of is mhl stuff, but I have already seen comments saying those work.
Let's keep things clean guys.
Read the user guide. It clearly states USB 2 cables will work on the Note 3. The USB 3 Plugin on the Note 3 allows for faster data transfers when connected to other devices with USB 3. I've connected my 3 to USB 2 devices without issues.
Sent from my SM-N900P using Tapatalk now Free
