[Q] What could be causing 3G / Data connectivity problems?
thekylebrody
89
It takes a minute or more to load simple non-flash web pages & the 3G fluxuates ridiculously..
Any Ideas!?
Its a brand new out of box DInc2
Thanks
Sent from my ADR6350 using Tapatalk
PvilleComp
4,146
603
Have you gotten all the OTA's?
Also, what is your signal strength? Not the Bars - the actual signal strength listed under menu -> Settings -> About phone -> status
The signal strength is a negative number like -92dBm The smaller the number the better your signal.
PvilleComp
4,146
603
-97 is not bad. you should have no connectivity problems with that.
Does it happen all the time or just in specific locations?
Sorry to have to ask all these questions, I'm just trying to isolate if it's a tower or phone problem.
Stelv
278
16
It could be that you are just not near a tower. What does the speedtest.net app say? Make sure the batter cover is seated properly and you could try toggling between global and cdma mode.
Also side note. You may want to factory reset after the OTA update. Some of us have had issues after the OTA but they are cleared up with a factory reset.
thekylebrody
89
Multiple areas. It seemed fine before the update so I'm going to try to reset it.
I read that over at XDA as well.
I just want to root and run CM7 :(
teddeli
78
5
Sometimes just taking out the battery for a minute then replacing it helps
thekylebrody
89
Maybe I had a good fascinate..
At least 2 down and 1 up
Sometimes 4-5 down and 2-3 up..
I'm just sick of these longer then normal load times..
cloudsofmana
