Help with voodoo color?
ThePlasticBling
82
7
Hi, I'm using the ED01 GeeWhiz rom with the OTB Reloaded 1.6 Voodoo kernel. The Problem I'm having is I don't know how to turn on the voodoo color. It says that the kernel includes voodoo color, but how do I turn it on? I can't find the option in voodoo control. Please help! Thanks!
atomD21
495
63
I am not totally sure. Every kernel I've used that had Voodoo Color in it would have the options for it just be there in Voodoo Control. I wasn't able to turn it off either. And, did you mean ED05 GeeWhiz? I would try a reflash of the kernel.
samahmed336699
