Please Help!
rd0311
15
Need some help! Please! When I try to install a rom I continue to get "failed to verify whole file signature" and "signature failed verification". I do have voodoo lag fix installed but I have disabled it before trying to install any thing. Everything I have tried to install is giving me the same error. Any suggestions? Details will be greatly appreciated.
Sta11i0n
958
151
Have you tried different ROMs to rule out any problem with a specific one? How are you trying to install it? Through ROM Manager? Installing a ROM zip from your SD card?
gunnermike53
3,194
652
you could download the voodoo uninstaller and run that from cwm. i dont know if voodoo just sucks or if i just suck, but i had nothing but trouble with voodoo. i finally got it off there and i wont put it back. but that just me.
rd0311
15
Will try uninstaller. Seems like everything I try I get the same error. Thanks!
rd0311
15
I am now getting error "Failed to in/cache/update.zip(invalid argument). Also, getting message in Rom Manager that I do not have enough space on sd.
gunnermike53
3,194
652
yeah, i was getting very similar massages when i had voodoo. thats why i will never put voodoo on mine again. i dont know if voodoo sucks or i suck, but voodoo was a nightmare for me. the uninstaller worked for though. however seeing as how the moderator guy and many of the expert guys are using voodoo, i am guessing the problem with voodoo was do to my newbness. my advice would be for newbs to leave voodoo alone until they get better at all this.
SOTK
244
62
Voodoo is very picky and temperamental. I agree that a lot of the problems people are having with it is due to inexperience; however, personally, I think Voodoo is just simply more trouble than what it's worth. For those that really need the fix that Voodoo provides, it's probably worth it, but I think for most, it's not needed.
aes55
Active member
Sep 12, 2010
32
+1
totally agree.
tress
