I did a similar thing. Made a backup before trying some changes. Didn't like them, restored... mucked up the boot
I tried everything listed here, and more, but still can't get the boot animation to work anymore.
Boot has audio, and shutdown has audio and video.
bootanimation.zip is there (system/media), and all files seem to be intact.
FYI - here is what I have tried:
recovered
messed up
deleted everything/cleared cache then recovered
still messed up
reinstalled through Rom Manager
still
reinstalled through CWM
still
Through Rom Manager, selected none
still there
system/etc deleted poweron.wav, bootanimation, bootanimation2nd
nothing on start, but power off still there.
found and deleted bootanimation.zip under system/media
same
found system/media/video...deleted all 66 .png images. system/media/audio/ui shutdown.ogg
interesting to see what you get with truely no shutdown info...
reinstalled through cwm
works except for no opening animation, but all the animations are in system/media/bootanimation.zip
moved bootanimation.zip to data/local
no change
moved to system/etc
no change
renamed to remove the zip
no change
moved to data/local
no change
moved to system/media
no change
Noticed the decs.txt file, in the zip, had a square image at the end of each line. Removed them (move file, unzip, fix, rezip, move back)
no change
moved to data/local
no change
renamed with no .zip
no change
no change
changed permissions rw-r-r
no change
back to bootanimation.zip with "squares", and changed permissions rw-r-r
no change
moved "no squares" to sytem/etc
no change
... wondering if I should have left bootanimation, bootanimation2nd alone?
"bootsamsungloop.qmg" is still in system/media, and the samsung logo appears. Which it always did, before the aperture logo did.
