Here is the answer for you two and anyone else who wants to go directly to red cwm and not bother with blue recovery. Right click on this link, choose "open in new window" and save the .tar file to your computer
http://db.tt/6dZUc7d
Connect your phone to your pc with debugging on, pull down notification bar, click on usb connected, click grey "connect usb storage" below green droid. When auto play pops up, click "open folder to view files", when the window opens delete update.zip from there. If you haven't already seen this part and done it, download this update.zip to your clockworkmod folder, go into the clockwork mod folder and delete recovery-update, rename this update to recovery-update:
MEGAUPLOAD - The leading online storage and file delivery service
Now on your phone, click the grey "turn off" usb storage box under the orange droid. Turn off your phone, pull the battery, open ODIN on your computer, hold volume down button on phone and connect phone to pc with usb cable. Flash the .tar file with ODIN, when ODIN is done, unplug phone, put battery back in, power up, and you will now be able to go directly to red cwm no matter what method you use.
