Page 2 of 9 FirstFirst 12345 ... LastLast
Results 26 to 50 of 210
Like Tree4Likes
  1. #26
    JaeKar99's Avatar
    Posts
    ROM
    ICS 4.0.4 build 8
    Default
    Edit: I would suggest using one of his Odin packages if you wish to accomplish this quickly. DXcon - I can help.
    Or...
    Did you select usb debugging and have the phone on stay awake under Settings> Applications> Development? - that may have been the issue -
    Here is a more detailed process in DXcons thread - Link
    Confucius: “Never use a cannon to kill a fly.” - Take off and nuke it from orbit.. ~~^^~~
  2. #27
    JaeKar99's Avatar
    Posts
    ROM
    ICS 4.0.4 build 8
    Default
    Christx1337, Welcome to Android Central. I hope that you are finding the answers to your situation.
    I will be watching this thread. Post if you need more assistance.
  3. #28
    APeaceOfStrange's Avatar
    Posts
    ROM
    Virtuous Unity
    Default
    is there a difference between the drivers in this thread vs the drivers that you install when using the droidxcon froyo packages?
  4. #29
    Landshark's Avatar
    Posts
    Global Posts
    4,417 Global Posts
    ROM
    Infinity & Pool Party
    Default
    Quote Originally Posted by APeaceOfStrange View Post
    I think these may be different drivers, but you are better off with the samsung drivers from DroidXcon's Froyo thread if they are working for you.
    Shouldn't we treat this world like the Garden of Eden and avoid the apple at all costs?
    Sometimes you go to the circus...........Sometimes the circus comes to you.
    Instructions on how to flash ROMs, Kernels, Patches, and Mods through clockworkmod recovery, CWM: DroidXcon's CWM Thread
    If you add me on Google+, please list your AC username as a nickname so I know who you are.
    Thanked by:
  5. #30
    jessie02's Avatar
    Posts
    Global Posts
    63 Global Posts
    Default unable to chmod /data/local/temp/rage.bin: No Such file exits error when rooting
    have looked at all the related threads and still cant find an answer..... Gone all the way back to D101 and still get the error, wiped cache, etc..... using the EZ root method. Any ideas? Thanks
  6. #31
    gunnermike53's Avatar
    Posts
    ROM
    Gummy, AOKP
    Default
    use one of dxc's odin packages. one click root is wonky sometimes.
  7. Thread Author  Thread Author    #32
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default
    Quote Originally Posted by jessie02 View Post
    Yeah if you have gone back to stock using odin you may aswell use my odin packages like gunner said . But in the future please give more detail so we can help you. Like what the error was
    Sent from my SCH-I500 using Tapatalk
    If i've made life easier buy me a Macchiato
  8. #33
    Default
    I am driving myself crazy here. Last evening I successfully rooted my fascinate then somehow accidentally deleted titanium backup which I think triggered something in my phone because now, when i reinstalled TB, it does not recognize my phone as rooted. I have tried 5-6x's today via the steps in this thread to root and it reports to be "successful" and it continues to say "complete", but is not rooted apparently. So I attempt to troubleshoot using "adb" in cmd and is says that it is not recognizable. Then I try to copy and paste the location directly into the end of the value table in environmental variables and I still cant locate adb. I am so lost and frustrtated and any help would be great.
  9. #34
    Default
    the easiest solution is to flash one of droidxcons odin packages. this will give root, cwm, and froyo rom, all in one step.
    Thanked by:
  10. Thread Author  Thread Author    #35
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default
    Quote Originally Posted by cl36 View Post
    +1 you already have a titanium backup, so you can restore after you flash the Odin package
    Thanked by:
  11. #36
    Default
    So I'm not sure if this is covered but I'm running into some issues trying to unroot. I did a few goofy things along the way so I hope you can follow along:
    1. rooted the phone and have superuser installed w supacleans initial dl09 via odin.
    2. usb function ceases to work but figured I'd use dropbox so i didn't bother trying to find a fix.
    3. tried to unroot(was going to bring it in to verizon for an exchange because of a damaged volume rocker) and i didn't have a pc handy. I download z4 root to try to unroot. worked but not so much.
    4. phone indicates that it has been unrooted BUT superuser is still there.
    5. now i have access to a pc. trying to use odin once again but detects the phone as a cd drive so it doesn't show up on odin. Once in a while odin will detect it but only with the battery installed(any problems with running odin/flashing with battery still in?)
    So now, how can I unroot and take it back to stock? trying to update superuser(will this help me unroot?) but automatic update failed.
    any help is appreciated. At this point, Im no longer taking it back to verizon but just want a clean install of having root. Phone functions as normal otherwise.
    *edit - I've also tried rooting again so i can unroot but am unable to do so. using z4(easiest method but obviously not as consistant) since I am just starting to learn but z4 continues to not respond.
  12. Thread Author  Thread Author    #37
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default
    Quote Originally Posted by moofilebot View Post
    put it in download mode while its plugged in and pull out the battery it will remain in download mode
  13. #38
    Default
    thanks DroidXcon, will try that right now.
    * duh forgot to ask, how can i put it into download mode while it's still on? is there another way to get into download mode other than, battery out, plug usb, vol down and power button? (oops, that's not dwnload mode at all, volume down only)
    edit 2: as of right now, phone is plugged in w battery. odin shows that the phone is connected but it doesn't show in win explorer. can i continue with odin method of reflashing?
    *edit 3: k, unable to get it into download mode. computer says usb drive not recognized if i plug the phone in with without the battery into download mode. doesn't show up in odin either.
  14. #39
    Default
    did you try using a different usb port?
  15. #40
    Default
    cl36,
    I have, same issue. It appears that regardless of which port I use windows proceeds to install drivers to what appears to be for a mobile device then after all that's done, still shows up as a cdrom.
    Will try another computer altogether for now cl36. Thanks
    *edit: success!! Tried it on a diff system and worked right on boot up after driver install. Stocked, now ready for some froyo luvin'. Thanks again for the help guys!
  16. #41
    sharvis14's Avatar
    Posts
    ROM
    KangBang 2.1/OTB v1.6
    Default
    I rooted my phone only and BLUETOOTH will not turn on....Please HELP
  17. #42
    Landshark's Avatar
    Posts
    Global Posts
    4,417 Global Posts
    ROM
    Default
    Quote Originally Posted by sharvis14 View Post
    Don't post the same question in multiple threads.
  18. #43
    sharvis14's Avatar
    Posts
    ROM
    Default
    Sorry could someone help me
  19. #44
    Default
    ok...so I did all of the instructions twice from post #4....i get to superuser already exists failed....titanium backup says im not rooted....how do i get rid of the existing superuser?
  20. #45
    Default
    Quote Originally Posted by dablitzkrieg View Post
    why didnt you try one of the odin packages that droidxcon and i suggested in posts #34 and #35?
  21. #46
    hillview's Avatar
    Posts
    ROM
    Stock for now!
    Default
    Is there a " What to do after root " thread? I'm running a DroidXcon 2.9.2 superclean package and don't know what to do next ?
  22. #47
    Dave95b's Avatar
    Posts
    ROM
    SC2.9x
    Default
    Can I return to stock just using my cell or do I have to be connected to a computer? I already have Red CWM on my cell. From what I've seen in the threads only covers being connected to a computer. Thanks
  23. Thread Author  Thread Author    #48
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default
    Quote Originally Posted by Dave95b View Post
    no you can not you need a computer
    Thanked by:
  24. #49
    Default I need help Unrooting
    Hi all,
    I feel as if I've gotten myself too deep w/ rooting my phone, and have decided the process is just not my thing.
    I want to remove the root entirely (superuser and all). Can someone help me get back my basic locked down Verizon fascinate? I'm still in 2.1 (EA28).
    I've been thumbing through the threads and having trouble finding what I need to know. Instructions or directions to instructions would be greatly appreciated.
    Thank you for your help!
  25. #50
    Default
    http://forum.androidcentral.com/veri...other-how.html
    Instructions to unroot are in the post above.
    TapATalkin From My SuperClean ComaVolt Kernel Fascinate
    Thanked by:
    Big Z
