[How To][Links] Themes, ROMs, Kernels, Boot Animations: 9-16-11
Landshark
4,434
1,382
113
JaeKar99
1,260
712
Someone posted over at XDA that the su 2.3.6.1 + busybox 1.19 zip file also works for rooting EC09. And imnuts and navenedrob are both putting together debloated/deodexed/rooted ROMs
That is great news.. Have you found a version of su+bb that is edify scripted?
I saw a post where someone was using CWM red - my guess is 2.x.
JaeKar99
1,260
712
ED01 CommROM v2.1 (patch update) - nitsuj17 - Please see download link (developer name for install instructions. - Updated: 6/20/11
This ROM requires: Full data wipe, Dalvik wipe, cache wipe.. prior to install to avoid possible issues.
CommROM 2.1 Patch - No wipe needed. Must be flashed over CommROM 2.0
Warning: Flashing the patch will clear your theme.. it will also make it so that you cannot use any theme designed for CommROM 2.0..
papa54
590
15
Newest Recoveries:
times_infinity
Voodoo CWM 3.x - *last updated 5.8 (version 3.0.2.8.x.ti)
jt1134
[RECOVERY] Updated ClockworkMod for ALL ROMs *last updated 3/30 (version 2.5.1.x) - Append - - - Odin File -|| - zip File
gizmodroid
Erasing the CWM Confusion (reference for cwr issues) *last updated 4.8.11 (version 2.5.1.x updated)
tonu42
CWM3 with voodoo *last updated (version 3.x)
Superuser + Busybox zip file - apend flash only..
thats all fine n dandy,, but where is the file,, read thru the whole postings and not once was the directions noted to allow someone to get the file..
JaeKar99
1,260
712
Which posting are you referring to? gizmodroid's post is reference only.. The other posts are on another forum where (downloading) requires a membership there.. Here are direct links to the files..
Voodoo CWM 3.x (zip) -|| - Odin - times_infinity
jt's 3/30 (version 2.5.1.x) - Append - - - Odin File -|| - zip File
CWM3 with voodoo (zip) - tonu42
JaeKar99
1,260
712
Re: [How To][Links] Themes, ROMs, Kernels, Boot Animations: 6/26/
Updated Thread - New Boot Animations:
Fourth of July Android America Boot Animation – JaeKar99
Animated Preview || Download – Flash in any CWM
Android + Linux Boot Animation – JaeKar99
Purple Hazze Boot Animation – JaeKar99
Hyper Space Loading Boot Animation – JaeKar99
JaeKar99
1,260
712
Re: [How To][Links] Themes, ROMs, Kernels, Boot Animations: 7/03/
Honey Bee (Honeycomb Boot Versions): (these boots are designed for a different device but have been formated to center on the fascinate)..
Honey Bee Blue Boot Animation - Android Shared
Animated Preview || Download - Flash in Any CWM
Honey Bee Green Boot Animation - Android Shared
Honey Bee Red Boot Animation - Android Shared
Happy Fourth of July!!! :cool:
joebob2000
711
22
Re: [How To][Links] Themes, ROMs, Kernels, Boot Animations: 7/05/
JaeKar, great job as always! Just an FYI, JT's CM7 build is now GB based, so it should be listed under 2.3 instead of 2.2. Thanks!
FasterN8
3
Re: [How To][Links] Themes, ROMs, Kernels, Boot Animations: 7/06/
Having trouble downloading a good copy of UKB2.0 with the pbj-50 kernel. The md5 code in the OP is saying that my downloads are bad.
I tried each of the first 5 links from the download page and all came up as 158,171 KB and all had a bad md5 check. Can anyone else verify this?
(Using "MD5 Check Utility v2.31" It validated all the other UKB files that I downloaded so far.)
JaeKar99
1,260
712
Is this your md5: 1092A4F02F668521D633670A80BA127C.. ?
I checked with the source and the first md5 was wrong.. The OP has been corrected the link is the same.
rbellis
Active member
Dec 15, 2010
29
Re: [How To][Links] Themes, ROMs, Kernels, Boot Animations: 7/12/
I am having some issues with the CM7. I downloaded the original and tried to update to the newest version but I am getting FC on youtube and cannot get titanium back up to work. It says my phone is not rooted. Auto Killer also seems to FC and none of my wifi tethers seem to work. Can someone please help me.
JaeKar99
1,260
712
I am not familiar with CM7 and really not sure if many users here have taken the plunge into that build.. You may get more response if you post in the the Verizon Fascinate Rooting, ROMs, and Hacks forum space with more visibility. I am afraid that your post may not be seen in this thread.
If you do not get help there - try posting on XDA
- or -
irc.freenode.net
#samsung-fascinate
mjszabo
18
3
Re: [How To][Links] Themes, ROMs, Kernels, Boot Animations: 7/20/
I was wondering if there was a comparison chart between all the 2.3 (Gingerbread) based ROMs?
Maybe that included the stability of each one and any problems associated with them.
And also included the install process, since it seems like most of them have different install requirements.
Are there anymore that are in development? I know post #5 says MIUI v5, but is it gingerbread based?
Also, what are most people using (Cyanogen, OMFGB, etc.)?
Thanks!
