SplatterSack
Just getting started, but have managed to root and lagfix as of last night Nice screenshots everyone. Keep 'em coming.
I would love to see a live wallpaper of this. Perhaps and constant stream.
JuicePlotterwhat "charge time" widget is that?
Using Launcher Pro Plus. Jorte Calendar Widget. In all my smartphone usage, Jorte's monthly view is the first app with a month view that is actually usable IMO. Highly recommended.
I am using Beautiful Widgets. The Clock Skin is blackcashmere with full transparency (basically I am after the font type and font color). Weather Skin is Standard Skin.
When you press the weather on the homescreen you get the screen below along with active elements (simulated rain, snow, lightning, fog etc etc). If this was a video the cloud on the left would move across the screen and past the sun, indicating Partly Cloudy. Note the screen is semi transparent, you can see my home screen in the background.
If I tap on the 5 day forecast I have it launch the Weather Bug Elite app.
Beautiful Widgets and Weather Bug Elite are paid apps.
can you tell me more about how to the clock skin is fully transparency?
I downloaded the black cashmere but i cant do that..
Press the weather icon from your home screen to bring up the 5 day forecast. Press Menu > Configure > then scroll down the customize section and you can hide the background completely (which is what I did on my screen and so did kilo) or you can set the transparency to whatever percentage you want (0% being the least visible).
How would you do that?I use the "ShootMe" app. From what I understand, you need to be rooted to take screenshots, or you need to hook the device up via the SDK and take the screenshot from the PC.
What is the name of those dock icons? I can't find them.
I've only had it for 2 days. I'm still trying to decide how I want it set up.
I tried several free clocks, because I'm cheap. But I ended up buying Beautiful Widgets. I also have Battstatt. Tho one in the notification bar is Gauge Battery Widget. I removed it in favor of the Battstatt. The dock icons are from Droidz.
