So, like many of you other GN owners I wanted a desk dock that uses the pogo pins to charge, and after seeing price tags on the UK versions I thought that even if VZW does sell a CDMA dock I wouldn't be spending that much. So I did some searching and decided to try to build my own. So far I have made a custom mold that fits the phone, ordered pogo pin headers, and ordered some microUSB extension cables. The plan is to just cut an extension cable in half, solder the pogo pins, and voila. A nice DIY desk dock. However, I cut the microUSB cable in half and decided to just probe the pogo pins to make sure everything works. From the palm touchstone mod I got the pin layout (+5V to pin closest to bottom, and ground to the pin closest to the power button). But when I probe it nothing happens, even after holding it there for a few seconds. So I guess my question is does anyone know of a forum thread or anything related to the pogo pins that states the CDMA GN can be charged through it? The palm touchstone mod use the contacts on the inside of the phone, I'm wondering if maybe the outside contacts don't really work (which sounds really stupid but holding the +5V and 0V to the pins should work).
Once I get this working I'm hoping to post a little show and tell on my home made dock.
