[GUIDE] How To Unlock Bootloader and Root Verizon Galaxy Nexus
mclarryjr
Retired Moderator
Nov 2, 2009
5,474
635
113
Re: [GUIDE] How To Unlock Bootloader and Root Verizon Galaxy Nexu
Thanks Cyber for the guide it work perfect for me :)
Upstreammiami
2,098
482
During reboot, DO NOT BATTERY PULL. The phone may loop and loop, but battery pulling will soft brick you and you will have to flash factory images to reset yourself. I was able to unplug from the computer while it was looping and the phone then rebooted itself. Or you may just have to wait a while since it is factory reseting during this first boot.
Reactions: Cyber Warrior
mclarryjr
Retired Moderator
Nov 2, 2009
5,474
635
113
Needed to read this a few minutes ago, was looping and looping so like a dumb a$$ I pulled the battery. Looks like time to start over and flash the factory images
should I give it a few minutes before trying that?
Upstreammiami
2,098
482
same here man hope cyber puts it on the OP.... how would you load the image if no sdcard ?
Cyber Warrior
Robots Will Kill
Nov 28, 2010
7,239
2,519
I'll add it to the instructions... honestly, im not sure how i got off of the Google screen :) I did eventually pull the cord which i guess is what eventually rebooted the phone.
mclarryjr
Retired Moderator
Nov 2, 2009
5,474
635
113
Not sure yet, wish I had recovery installed to be able to wipe data that would have worked (maybe). Has to be a work around some where.
here is what i'm trying, I'll let you know if it works
Originally Posted by MBerlowitz5181 View Post
I just ran a system wipe/ recovery using the bootloader menu... back up and running.
All i did was get back into bootloader by holding both VOL up and VOL down then power. once in, i went used vol down to scroll to recover, and then used power to accept. after it ran (5 minutes) it booted fine!
panitsos
289
15
are you kidding me? did we soft brick our phones? that sux what now? cyber going to put up some instructions?
Cyber Warrior
Robots Will Kill
Nov 28, 2010
7,239
2,519
Actually... the whole phone gets wiped. Including whats considered the sd card.... at least for me it did. Good thing I only had a few test pictures that i had taken.
Can any one else confirm that the entire phone was wiped.... including storage?
JkdJedi
2,197
218
That sounds right to me, android central s last podcast mentioned to unlock your bootloader right away when you get your nexus for that very reason.
Sent from my DROIDX using Tapatalk
10001110101
225
35
Never messed with ADB until today. Easy as pie. Unlocked and Rooted!!
kichard
21
Mine was sitting at the google screen for a serious 15 minutes. I pulled the battery, booted up just fine and super user is working correctly. Installed Rom Manager and flashed Clockwork. Idk why you guys are getting boot loops. Maybe I got lucky?? Idk 15 minutes should be more than enough time to load the system images back up. To fix the soft boot wouldn't you just go to the stock recovery and delete data/factory reset?? I mean that's what I would do...
panitsos
289
15
ok so i've got a android guy on his back with a red triangle coming out of his stomach did i brick my phone?
panitsos
289
15
well i'm between google and the spash screen in between keeps saying android upgrading but its been doing it for over a half hour now, sure hope i didnt do anything to the phone just keeps looping between those two screens
NewAge
755
64
Nope. Pull the battery and turn back on. With root explorer goto /system and rename the file "recovery-from-boot.p", put a 1 in front or .bak. Then with ROM manager reflash CWM and you should be good to go. Boot into CWM.
panitsos
289
15
how can i get to the root explorer if the phone keeps looping? and where would the root explorer be? sorry i'm not too good with tech talk
tivativa
