Page 1 of 2 12 LastLast
Results 1 to 25 of 48
Like Tree41Likes
    TGreg104's Avatar
    Posts
    Global Posts
    59 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Axi0m 2.3/ Lean v1.2.2
    Default Android 1.0 driver problem? Check here.
    Whats up guys, hope everyone is enjoying their gnex as much as me.
    I just wanted to share some info on what I found to be a very frustrating problem when rooting the gnex, the android 1.0 driver. Not everyone but a lot of people have been stuck at the step when you do fastboot-windows oem unlock/fastboot oem unlock and it says "waiting for device" at which point your computer is trying to install the android 1.0 drivers which it cannot find.
    Solution:
    Download: PdaNet
    Once downloaded, install the software. When thats done go into control pannel>hardware and sound>device manager and look for the android 1.0 driver with the yellow exclamation point. Right click and hit 'update drivers'. Browse your computer manually instead of having it search for you. Then enter this path. c:/program files (x86)/PdaNet for Android/usbwin. You'll get a security warning, but install anyways. Once this is done, you're good to go.
    I just wanted to share because I spent 5 plus hrs (embarrassing, I know) trying to figure out how to get the driver to install.
  2. #2
    dmonzel's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Some Jelly Bean ROM
    Default Re: Android 1.0 driver problem? Check here.
    It's like you can read my mind. Thank you tons.
    TGreg104's Avatar
    Posts
    Global Posts
    59 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    No problem, it was soo frustrating! I just figured if I could save just one person the headache I had, itd be a success haha.
    dhee9000, nsf9206 and alex777 like this.
  4. #4
    TRZ06's Avatar
    Posts
    Global Posts
    27 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I ran into the same issue as well, and resolved it by updating the driver with the ADB Bootloader Interface driver from the driver folder in the SDK.(can't remember the path offhand)
    _Gir_ and nsf9206 like this.
  5. #5
    deadpenguins's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    GummyCHARGED FE 2.0
    i. love. you.
    maggio08005 likes this.
    TGreg104's Avatar
    Posts
    Global Posts
    59 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    haha no problem brotato
  7. #7
    _Gir_'s Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by TRZ06 View Post
    I did the same.
  8. #8
    kjreid1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you! Wish I found this earlier!
    ehhrundf likes this.
  9. #9
    Montclair's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Rooted/Stock
    Default
    Quote Originally Posted by TGreg104 View Post
    Solution:
    Download: PdaNet
    You can also use the drivers here:
    http://dl.dropbox.com/u/4174784/usb_driver.zip
    It worked for me.
  10. #10
    xelhabb's Avatar
    Posts
    Global Posts
    204 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    3.0.8-gaaa2611, unlocked
    Yes! This is a pain in the a$$ everyone faces. I had to reinstall the driver even after flashing my previous GNEX. I had an insurance replacement and met the same issue again when unlocking the second time.
    The drivers must be installed via the computer device manager and then going through the folders in SDK for the driver file. "ADB bootloader interface" is the file. If you search on the XDA site there is a step by step procedure but you have to follow it to a tee or it will not work.
    UGH!
  11. #11
    iam_hason's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    you're amazing <3
  12. #12
    5h4un360's Avatar
    Posts
    Global Posts
    210 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Codenameandroid 1.3
    Default
    just ran into this problem before I had to go to work! Will try once I get home! Wish me luck
    drissa and samssatellite like this.
  13. #13
    dniel21's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thanks
  14. #14
    sakooo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thanx amn its working ..
  15. #15
    RescueXJ's Avatar
    Posts
    Global Posts
    6 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP MS6
    I just registered to download this, wanted to say thank you!!
  16. #16
    aman1234's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i can't find android 1.0 at the panel control
  17. #17
    scottfromga's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank jeebus for this thread!
  18. #18
    balticzar's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks a TON!!!! This was hanging me up from root and driving me crazy. Much appreciated.
  19. #19
    wise04's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Dude!!!! Thank you very much this was very helpful!!
    btw, I have a hugeee problem an im kida new on this, I accidentally bricked my evo 3d i have a hboot 1.50 s-on and it says unlocked.. its looping, it never passes the HTC screem..
    I need help Thank you guys!!
  20. #20
    dodge2012's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thank youuuuuuuuuuuuuuu!!!!!
  21. #21
    cristiangimenez's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    tanks good work ..!
  22. #22
    bgapfire's Avatar
    Posts
    Global Posts
    167 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock/ rooted
    I am a super NOOB at rooting. I am using Wugfresh's root method for v1.4 and my phone is currently stuck at the bootloader screen. My computer will not recognize my device to install the additional drivers. Can I pull the battery and start over or is there something else I'm supposed to do?
    Thanks in advance for your assistance.
  23. #23
    hitechhall's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I can't count how many times I want to thanks U
  24. #24
    dalellagas's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you
  25. #25
    aggozzur's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Dude... Thanks SO -EFFIN - MUCH!!! I. LOVE. YOU. You get a naked pic of my hot asian girlfriend who I haven't met in person yet... Infact, I have 3 of them, what one you want?
