I downloaded and installed the first CM 10.1 build, not paying too much and attention and thinking it was just another CM 10 nightly. I never saw the warnings that one shouldn't use the CM Updater to do this, but I was able to figure out how to fix the Clock app issues and install the new gapps without too much trouble. The ROM seems to be working mostly fine now, and I've updated to newer nightlies since, but there's one persistent problem. On the lock screen, the Action Bar appears with a single circular icon in its center. Touching this icon expands a radial menu with a single item--a shortcut to Google Search--which, after the associated animation, appears in exactly the same position as the lock icon. This results in a mutant, hybrid lock-search icon, which is unsightly and hopefully unintended.
I can't find a UI-based way to change the behavior of this lone Action Bar button on the lock screen, or a way to hide it. I tried to clear the Trebuchet data, thinking maybe this was the result of data from the previous version of the launcher being loaded under the new version with bad results, but that just got me a blank home screen. I'd like to know if anyone else using CM 10.1 on a Verizon GNex has this problem, or has had it. It you never had the problem, please share how you installed the ROM; if you've had the problem but solved it, please let us know how. Thanks in advance for any help.
