- 12-17-2011, 10:24 AM
Thread Author #1
Android 1.0 driver problem? Check here.
Whats up guys, hope everyone is enjoying their gnex as much as me.
I just wanted to share some info on what I found to be a very frustrating problem when rooting the gnex, the android 1.0 driver. Not everyone but a lot of people have been stuck at the step when you do fastboot-windows oem unlock/fastboot oem unlock and it says "waiting for device" at which point your computer is trying to install the android 1.0 drivers which it cannot find.
Solution:
Download:
Once downloaded, install the software. When thats done go into control pannel>hardware and sound>device manager and look for the android 1.0 driver with the yellow exclamation point. Right click and hit 'update drivers'. Browse your computer manually instead of having it search for you. Then enter this path. c:/program files (x86)/PdaNet for Android/usbwin. You'll get a security warning, but install anyways. Once this is done, you're good to go.
I just wanted to share because I spent 5 plus hrs (embarrassing, I know) trying to figure out how to get the driver to install.Thanked by 44:+ Show/Hide list of the thanked -
abjackson1103, Addy Firman, andrejsosipovs, aoat, Atratus, basbelasii, Bram-Schats, CaptGeno, chadwick609, cristiangimenez, deadpenguins, delquattro, diavas2007, dmonzel, Dylan Rhorer, fascilongo, fisherbrettster, Froens, gianner, HannibalSelecta, Jackson8812, jsteuart, kjreid1, komradefox, Linnau, maxdrive10, MrZackarius, Mwa Wak, nickh186, nsf9206, reisse, scottfromga, sharanpatel7, Silly Pirate, somezade, tanisacolor, tec602, Teymur Tahmazov, voxxer, Waqas Rehmat, waszka0, whitedevil01, wilburwilde, zen.shaolin
- 12-17-2011, 08:02 PM #2
- 12-18-2011, 09:47 AM
Thread Author #3
Re: Android 1.0 driver problem? Check here.
No problem, it was soo frustrating! I just figured if I could save just one person the headache I had, itd be a success haha.
- 12-18-2011, 11:16 AM #4
- 12-18-2011, 07:52 PM #5
- 12-18-2011, 09:02 PM
Thread Author #6
haha no problem brotato
- 12-18-2011, 09:12 PM #7
- 12-29-2011, 04:23 PM #8
- 12-29-2011, 08:45 PM #9Thanked by 2:
- 12-30-2011, 08:24 AM #10
Yes! This is a pain in the a$$ everyone faces. I had to reinstall the driver even after flashing my previous GNEX. I had an insurance replacement and met the same issue again when unlocking the second time.
The drivers must be installed via the computer device manager and then going through the folders in SDK for the driver file. "ADB bootloader interface" is the file. If you search on the XDA site there is a step by step procedure but you have to follow it to a tee or it will not work.
UGH!Nextel Flips > Motorola Slider > Blackberry Storm 9530 > Motorola Droid X > Galaxy Nexus - 01-03-2012, 03:22 PM #11
- 01-03-2012, 04:04 PM #12
just ran into this problem before I had to go to work! Will try once I get home! Wish me luck
Sent from my Galaxy Nexus using TapatalkThanked by: - 01-06-2012, 07:20 PM #13
- 02-26-2012, 12:26 AM #14
- 03-03-2012, 04:05 PM #15
I just registered to download this, wanted to say thank you!!
- 04-09-2012, 10:22 AM #16
- 04-22-2012, 09:48 AM #17
- 05-09-2012, 09:50 AM #18
- 05-16-2012, 07:45 PM #19
Dude!!!! Thank you very much this was very helpful!!
btw, I have a hugeee problem an im kida new on this, I accidentally bricked my evo 3d i have a hboot 1.50 s-on and it says unlocked.. its looping, it never passes the HTC screem..
I need help Thank you guys!! - 05-21-2012, 01:56 AM #20
- 06-14-2012, 09:07 AM #21
- 06-14-2012, 09:26 AM #22
I am a super NOOB at rooting. I am using Wugfresh's root method for v1.4 and my phone is currently stuck at the bootloader screen. My computer will not recognize my device to install the additional drivers. Can I pull the battery and start over or is there something else I'm supposed to do?
Thanks in advance for your assistance. - 07-13-2012, 10:46 AM #23
- 07-27-2012, 11:46 AM #24
- 10-14-2012, 01:58 AM #25
Reply
