Soft Key Background Mods....33 total
bakerbert
359
82
Soft Key Background Collection
Red Wings
http://dl.dropbox.com/u/51662572/softkeys_red_Wings.zip
Android Robot
ICS Blue - http://dl.dropbox.com/u/51662572/softkeys_Android_ICSblue.zip
Red - http://dl.dropbox.com/u/51662572/softkeys_Android_red.zip
Green - http://dl.dropbox.com/u/51662572/softkeys_Android_Green.zip
Heart
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Heart.zip
Heart Banner
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Heart_Banner.zip
ICS Logo
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_ICS_Logo.zip
Nexus Logo
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Nexus_Logo.zip
Android Central Logo
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Androidcentral_Logo.zip
Superuser
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Superuser.zip
Jolly Roger
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Jolly_Roger.zip
Team Kang (show you AOKP Love)
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Team_Kang_Logo.zip
Star wars Light Sabers
Blue - http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Lightsaber_Blue.zip
Green - http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Lightsaber_Green.zip
Red - http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Lightsaber_Red.zip
Triple Diamond
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Triple_Diamond.zip
San Francisco Giants
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_SF_Giants.zip
Dodge Ram Logo
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Dodge_Ram_Logo.zip
Cummins Diesel Logo
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Cummins_Diesel_Logo.zip
Flux Capacitor
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Flux_Capacitor.zip
Ohio State Logo
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_OhioState_Logo.zip
Nashville Predators Logo
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Nashville_Logo.zip
San Francisco 49's Logo
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_SF_49ers.zip
Detroit Tigers Logo
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Tigers_D.zip
Game of Thrones Crown
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_GOT_Crown.zip
Detroit Lions Logo
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Detroit_Lions.zip
Android Jellybean Jar
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Jellybean_jar.zip
University of Michigan Logo
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_UofM_Logo.zip
Yankee's Logo
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_Yankees_Logo.zip
US Marines Logo (single color)
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_USA_Marine_Logo.zip
US Marines Logo (Chrome/Gold)
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_USA_Marine_Logo_Fancy.zip
Michigan State Spartan's Logo
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_MSU_LoGO.zip
Michigan State Block S Logo
http://dl.dropbox.com/u/51662572/Soft Key Background/softkeys_MSU_S_LoGO.zip
Instructions
These should work on any ROM
1. Download file
2. Transfer to SD card
3. Run through Zip Themer or Metamorph (I use Zip Themer)
4. Boot in to CWM
5. Flash File created in Zip Themer
6. Enjoy
Important
When using Zip Themer:
Make sure you update Edify every time you change your ROM, or the first time using ZipThemer
open Zip Themer > settings > update Edify > select flashable file browse> locate on your device the ROM you are currently using > hit configure > wait for the success popup
Notes:
I have not been able to make these work on any rom with a theme chooser theme installed, stock theme is the only way to use these :'(
If you use a rom that can change the glow color, it will change the entire background to that color. No multicolored backgrounds on AOKP :'( (I will test others tonight and report back)
I did not wipe anything when installing these files and it worked fine.
You might want to make a nandroid just in case.
I am not responsible if you destroy/brick/make your phone so hot you can take a bong hit off of it/other bad stuff.
I can make just about any logo/Pic in to a soft key background, so if there is something you would like made...Ask away. I will do my best to make it for ya.
Enjoy!!
mwong
9
Re: Soft Key Background Mods....15 total
Can you make a San Francisco Giants baseball team one. The logo that says Giants, over the middle of a baseball? Much appreciated if you can have that done.
mclarryjr
Retired Moderator
Nov 2, 2009
5,474
635
113
These are great I'm really liking the Red Wings one.... thanks for sharing
bakerbert
359
82
OP Updated
Added San Francisco Giants Logo and Silver Triple Diamond
More ICS Blue ones on the way,
mwong
9
Re: Soft Key Background Mods....17 total
Thank you for the Giants one! Took some trial and error figuring out how to use zipthemer, but once I got it working, awesome!!!
sicario666
2,928
365
83
Lookin good. I was gonna ask for some skulls but you're ahead of the request game. I just grabbed the SU icon. Thanks!
Dropped from Liquid Nexus via Tapatalk2
steveinil
487
4
very cool i assume you can use these if your running a custom rom? i am running gummy nex.. can you do one with like the dodge ram or cummins
C on it?
steveinil
487
4
yeah both look greatthanks.. got the zip theamer looking forward to trying it out when i get time
tress
