CWM vs. TWRP
2defmouze
3,945
1,552
Lol since I joined here I stopped googling. But thank you....
Lol Nah I didn't mean it in a rude way, just I've always learned the answers to most questions and how to do stuff by good old fashioned Googling :)
Reactions: CA1NE and oxymoron
CA1NE
98
17
Strange thing happens when I Google about nexus/hacking.....I end up in android central lol I love you guys (no homo).....(maybe a little)
whthotg8
Active member
Dec 9, 2010
31
Can someone comment on if it is worth the $6 for ROM manager premium for updating rom? Or is it easier to do it manually? Also, do I need to wipe all data and clear All cache before updating to newer version?
2defmouze
3,945
1,552
Its absolutely NOT worth it. Do things manually in recovery, its something you should get comfortable with :)
Updating to a new version of the same ROM you can sometimes to a dirty flash = wipe caches and wipe system. If you run into bugs or issues you probably need to do a full wipe, as in wipe data/factory reset as well.
Reactions: dmmarck and CA1NE
whthotg8
Active member
Dec 9, 2010
31
Thanks for the quick response and information. I will do it manually. Prob just do a full reset just in case.
pmcd1962
84
6
How do I uninstall ROM manager? When I select it from my app drawer the only option is "app info"
2defmouze
3,945
1,552
Sounds like you're on CM10 which installs it as a system app. You can either use something like Root Explorer to just delete it from /system/app... or you can use Tibu to uninstall it.
I mean you don't have to stress it.. you can leave it installed even if you're not using it, won't hurt anything. I absolutely hate that CM installs it automatically. Hate having that app on my phone :)
stkiswr
Twrp all the way! Love how useful the features are. Have had 0 issues restoring jelly bean backups. Flashing any roms or mods w 0 problems. Very happy.
VDub2174
Moderator Captain
Trusted Member
Dec 28, 2009
3,921
86
48
I'm a big fan of TWRP!
It's easy to navigate and has been running smoothly for me ever since I installed it on my phone.
jean15paul
Trusted Member
Jun 17, 2011
1,222
41
48
Lot's of good info here. Thanks to everyone who contributed. I'm a new rooted (rooted and flashed for the first time 2 or 3 weeks ago. I had planned to use CWM because I just heard it discussed a lot more than TWRP, but I ended up using TWRP because the dev of the specific ROM I wanted to flash recommended TWRP with that ROM, so I've never used CWM. I have been very happy with TWPR. It's really easy.
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
Hopefully it's not installed as a system app. If that's the case, use Root Explorer and go get it manually :).
Non
