EvanM3
Everyone with M1, can they try the clock thing I described?
Go to Settings, then ROM Control, then Clock. Set "short press" (or whatever the hell the other option is that isn't long press), select "Alarms."
Go to the home screen, pull down the notification drawer, and tap the clock. Force close?
I tried it and I get nothing. On the other hand, long press for alarm works as it should. No force close though
