- 12-18-2011, 12:55 PM
Thread Author #1
[issue] Regarding multitouch in GNex
So... I have the LTE Galaxy Nexus rooted and unlocked.
Everything seems fine, however I have issue with multitouch.
If i run a game (such as heavy gunner and any sort of those games),
as I move with left side of the phone (they usually have joystick there)
the right side of the phone would go unresponsive. Here's the link which I found on youtube,
where he shows the issue with a multitouch testing app.
I have tested out the app myself, and got the same result.
To add on, if I reboot the phone, it would work flawlessly,
and after awhile it would display the issue again,
so I assume its not a hardware issue.
Anyone have the same issue, or even better, any solution?
Thanks in advance
- 12-23-2011, 04:29 AM #2
Re: [issue] Regarding multitouch in GNex
Definitely have the exact same issue. It is quite annoying actually.
- 12-26-2011, 03:06 PM #3
i'm having the same problem. i was playing dead space and it was working fine, but then after a while it started having problems so i downloaded the touch test app and it was showing a problem on the right side of the screen (the portion of the screen closest to the on-screen controls). hopefully someone has a solution for it...
- 12-26-2011, 03:20 PM #4
- 12-26-2011, 05:06 PM #5
- 12-26-2011, 07:07 PM #6
Turn your screen off then back on. Quick fix until they fix the problem.
Thanked by: - 02-05-2012, 02:59 PM #7
Reply
