Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Kaizmuth
    Default Odd problem with Google contacts
    I have a problem with contact in my Nexus. I frequently go to dial a contact that I know is in my Google contacts, but can't find it in contacts. If I go into contacts, settings, contacts to display, customize, uncheck a box, then recheck it (all are checked already), the the missing contacts show up again.
    I can't figure out why they keep disappearing in the first place. Any ideas? This happens a couple times a week at this point.
    I have all my contacts in Google, and don't save them anywhere else.
    SoCalBIGmike likes this.
  2. Thread Author  Thread Author    #2
    Default Re: Odd problem with Google contacts
    Wow. no need else has has this happen or has any suggestions?
  3. #3
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Have you tried wiping them all out and resyncing?
  4. #4
    dflores's Avatar
    Posts
    ROM
    AOKP M3!
    I would start with force stopping the phone app and then clearing the data. If that doesn't work, I have no idea.
