Verizon radios General question.
jonsnowden
54
Do the updated Verizon radios need to be reflashed every time a new rom is installed? Updated to 4.2 aokp and just want to make sure I'm running the best radios. Thanks
zkSharks
Retired Moderator
Mar 15, 2011
2,013
75
Radios are flashed to your phone separately from the ROM, kernel, and recovery. Flashing a custom ROM won't update your radios, but flashing an OTA update package would change them if the OTA included a radio update. Here is zero's thread for the Galaxy Nexus radios, and here's the one on RootzWiki.
Simply check those lists above and check the "Baseband version" in your phone's settings. If you're running the latest one, you're good to go. But the short answer is that no, under normal circumstances the radios are not touched when a custom ROM is flashed.
