Results 1 to 21 of 21
- 02-11-2013, 12:47 PM
Thread Author #1
- 02-11-2013, 02:49 PM #2
- 02-11-2013, 03:01 PM
Thread Author #3
- 02-11-2013, 04:27 PM #4
Re: Considering rooting my note2
At this point, my best advise is.............Backup backup backup, as soon as you can. Not that anything will go wrong, but it could and if you have gotten recovery on your device you can at least get back to where you started. There are quite a few good roms now too. Clean rom, beans and of course cyanogen. Just depends on your tastes. Have fun!
- 02-11-2013, 07:25 PM #5
Do you have a link to this? How do you know if you have this update already? I'm assuming that I have it and want to make sure. The original way here to root and unlock will not work if you have this update and Im assuming possibly brick your phone? I just want to be absolutely sure of what Im doing before I start it and am using the right process!
I really appreciate all the hard work everyone has put into this! - 02-11-2013, 07:47 PM #6
- 02-17-2013, 11:58 AM
Thread Author #7
- 02-19-2013, 10:59 AM #8
- 02-22-2013, 11:14 PM #9
- 02-22-2013, 11:40 PM #10
If you unlock and leave it stock then yes it will update but after the update it will re lock your bootloader and you may lose root and may not be able to root again until someone finds another root method.
I would just root and unlock and not update until a rooting method is available for whatever the update is to.
From my Galaxy Note 2 via Tapatalk - 02-23-2013, 12:12 AM #11
- 02-23-2013, 12:15 AM #12
- 02-23-2013, 12:20 AM #13
That won't work if they sneak a new bootloader in there. Seems silly to even consider an ota after rooting. Developers will be on top of it and put out a rooted version of it or update a custom rom with it.
Sent from my SCH-I605 using Android Central Forums - 02-23-2013, 12:25 AM #14
- 02-23-2013, 12:58 AM #15
- 02-23-2013, 01:02 AM #16
- 02-23-2013, 01:46 PM #17
- 02-23-2013, 02:52 PM #18
- 02-23-2013, 02:53 PM #19
If you have used Adam Outler's jailbreak to gain root and unlock your bootloader you do not want any future OTA from Verizon to run even if you have a program like Voodoo Rootkeeper. The OTA will conflict with the unlocked bootloader. Since you still have the stock VRALL4 ROM the OTA will try to run. You can and should as soon s possible stop the OTA from running by freezing the SDM 1.0 app with a program like Titanium backup at the Playstore. You could also rename the .apk which I forget the the name of right now.
If you have root access but you have a stock ROM and your bootloader is still locked you should be able to let a future Verizon OTA run and save your root by using a program like Voodoo Rootkeeper.Last edited by universeand; 02-23-2013 at 03:13 PM.
- 02-23-2013, 03:57 PM #20
- 02-23-2013, 06:58 PM #21
Seriously considering rooting my N7… Advantages/disadvanages?
By return_0 in forum Nexus 7 Rooting, ROMs, & HacksReplies: 1Last Post: 01-02-2013, 07:05 PM -
Considering rooting my SGS2. Not sure...
By badbrad17 in forum T-Mobile Galaxy S IIReplies: 13Last Post: 11-01-2012, 03:07 PM -
How do I know If I successfully rooted my droid?
By REC0GN1ZE in forum Motorola Droid Rooting, ROMs and HacksReplies: 7Last Post: 08-03-2010, 08:44 AM -
Cant Root My Droid :(
By Sooks in forum Motorola Droid Rooting, ROMs and HacksReplies: 3Last Post: 12-18-2009, 02:05 AM -
Need help on my rooted my touch 3g hero rom
By VoLoDaR1 in forum HTC Hero Rooting, ROMs, and HacksReplies: 1Last Post: 12-17-2009, 08:34 AM
Reply
