Will the new Sandisk 128GB MicroSDXC card SDSDQUA-128G-U46A work inside the Verizon Galaxy Note 2?
FlyingBackwards
50
Will the new Sandisk 128GB MicroSDXC card, SDSDQUA-128G-U46A, work inside the Verizon Galaxy Note 2?
Re: Will the new Sandisk 128GB MicroSDXC card work inside the Verizon Galaxy Note 2?
Well, since it isn't available for sale anywhere and isn't even referenced on Sandisk's web site, its probably a moot point either way.
It is possible, but as the manual states 64 gb is max. Could just be because that is the largest available at the time of writing.
Samsung has a 128 gb version on their website as well, so who knows, until they try it.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Since MicroSDXC spec is up to 2TB, I guess the Note 2 can accept a 2TB card. (if and when it's available, probably at $1000 a card? :) )
Yes it'll work. I use a micro sd to sd card adapter in my Note 2 with a 128gb card and it's fine.
Where does one get a micro sd to sd card adapter, and how do you make it work with the Note 2?
Thanks.
So you have a 128gb microsd card that your note2 sees properly? And then you use a microsd to sd adapter to use in what your computer?
You have it backwards. He has a 128GB SD card that he uses an adapter to get it to read on the Note 2.
I was wondering. So he reads it with the usb port.
Sent from my AT&T Samsung Galaxy S4 using Tapatalk II
Oh nice. So the ribbon goes into the microsd slot?
thats what I am wondering, can you take a pic and show us how that works, I dont mind dropping 100 bucks if I am for sure it will work!
snacks1233
