Results 1 to 13 of 13
- 12-26-2012, 08:20 PM
Thread Author #1
HELP! My Verizon SHC-I535 won't boot and got System software not allowed after it was running
Do I have a brick NOW?
Installed OTA Jellybean update last week everything ok but I hated the verizon apps running in background so I tried my first custom ROM this morning and it ran fine for a few hours via this approach: .
I used ez-unlock and it said device was unlocked. Everything seemed fine for hours and multiple boots and then I got the "SYStem sofware not authorized by Verizon Wireless" etc. I can't even boot into clockwork mod recovery when I could before. I saw numerous instructions saying use Odin and recover with Verizon original STOCK ROM and boot up the phone and put it on it. THe problem is the phone won't Boot to allow me to put a STOCK ROM on the phone to attempt to recover. Does this mean these recovery attempts only work for a phone which won't boot that was running before the Verizon Jellybean update installed? This recover assumes windows will recognize the phone. It won't now cuz you have to boot it: [GUIDE] Restore Back to Clean Factory Stock UPDATE 10/23
Any help appreciated.
Thanks Anna - 12-26-2012, 08:27 PM #2
Re: HELP! My Verizon SHC-I535 won't boot and got System software not allowed after it was running
Your pc will recognize your phone in download mode.
Volume up+home button, continue to hold and then press power and hold until you reach a screen that asks you to press volume up to continue. Press volume up. You will then be in download mode. Then plug in usb cord. Your will then see com port light up in the Odin application
From my Galaxy Note 2 via Tapatalk - 12-26-2012, 09:26 PM
Thread Author #3
Thank you for replying but unfortunately I tried that before in download mode where you see the green Classic Android guy and it says Downloading.....Do not turn off target!! and Windows saw it when I put the ROM on and used it but NOW after the Verizon message and plugging it into USB Windows no longer sees the device. I then tried my wifes laptop and downloaded the samsung drivers again for the phone as I did before got Odin ready but on her puter it too said drivers successfully installed but the phone won't appear there either. START>COMPUTER. I opened up Odin and there is a blue COM which says:ID:COM and then a blue thing below it which says: 0:[COM5] it lit up when I plugged the phone into the usb port while phone was in download mode. I then did the following with Odin in Download mode i PDA' as I did VRALEC.bootchain.tar.md5 and then tried to boot into recovery mode again but then Verizon warning came up again so I am not able to get into recovery mode. Also above in ODIN at top where it says Odin 3 it only has Model name
the latter doesn't have the name of my device. Can I recover? Welcome your next suggestion. Thanks Anna...Happy Holidays!
- 12-26-2012, 09:57 PM #4
The blue com port is correct so it sees the phone. You need to go over the steps in this thread
http://forums.androidcentral.com/sho....php?p=1979796
If you can not do this let me know and I will screen share and do it for you
From my Galaxy Note 2 via Tapatalk - 12-26-2012, 11:33 PM
Thread Author #5
- 12-26-2012, 11:47 PM #6
- 12-26-2012, 11:49 PM #7
- 12-27-2012, 12:00 AM #8
- 12-27-2012, 12:25 AM #9
- 12-27-2012, 12:26 AM #10
- 12-27-2012, 12:32 AM #11
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> VRALEC.bootchain.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/013> Added!!
<ID:0/013> Odin v.3 engine (ID:13)..
<ID:0/013> File analysis..
<ID:0/013> SetupConnection..
<ID:0/013> Initialzation..
<ID:0/013> Get PIT for mapping..
<ID:0/013> Firmware update start..
<ID:0/013> aboot.mbn
<ID:0/013> NAND Write Start!! - 12-27-2012, 12:37 AM #12
- 12-27-2012, 12:39 AM #13
My HTC One V won't boot completely after custom rom installation
By fifamm96 in forum General Help and How ToReplies: 1Last Post: 12-30-2012, 04:25 AM -
Phone won't boot and I need it bad for hurricane Isaac
By QuincyP1994 in forum HTC Wildfire SReplies: 0Last Post: 08-29-2012, 05:02 PM -
Help, my Nexus is stuck in a boot loop
By JBMacGill in forum Verizon Galaxy NexusReplies: 5Last Post: 03-31-2012, 10:45 AM -
Help troubleshooting: LogicPD welcome screen, won't boot SD card
By glanceup in forum Barnes & Noble Nook ColorReplies: 0Last Post: 07-04-2011, 09:36 PM -
Help. Problems with phone. Wifi won't activate and SD card keeps disappearing
By mrputzy in forum AT&T CaptivateReplies: 3Last Post: 10-27-2010, 07:22 PM
Reply
