Problems with Rooting S3 after Stock Restore
Joseph Myers
3
Hi, I recently returned to factory defaults (4.1.1) after trying out CM on my Galaxy S3. I am now trying to root my phone (and eventually create a backup), but I am having problems with Rootdebugfs (superuser and superSU). Here is the output of the superSU version:
Step 1 - Setup...
Copying chainfire's SU files:
Copying chainfire's SU:
failed to copy 'su' to '/data/local//su': Permission denied
Copying debugfs:
failed to copy 'debugfs' to '/data/local//debugfs': Permission denied
Copying debugfsinput:
failed to copy 'debugfsinput' to '/data/local//debugfsinput': Permission denied
...done copying files.
Linking /system to tmp...
failed on '/data/local/tmp' - Permission denied
link failed File exists
...done linking /system
Rebooting...
rm: File not found by ext2_lookup while trying to resolve filename
This just means there wasn't an existing root/SU found on your phone.
Press any key to continue . . .
* server not running *
Unable to chmod /data/local/debugfs: No such file or directory
/system/bin/sh: can't open /data/local/debugfsinput: No such file or directory
Cleaning up...
Restoring tmp...
rm failed for /data/local/tmp, Permission denied
failed on '/data/local/tmp.bak' - No such file or directory
...done restoring tmp
Removing files...
rm failed for /data/local/su, No such file or directory
rm failed for /data/local/debugfs, No such file or directory
rm failed for /data/local/debugfsinput, No such file or directory
...done removing files.
Rebooting...
Testing chainfire's SU file installation...
/system/bin/sh: /system/xbin/su: not found
uid and gid should both be 0.
Are they? (y/n): n
Does anyone know why I'm missing those /system files?
Kage87Z
162
I understand that debugfs does not work for 4.1.1.
Step 1 - Setup...
Copying debugfs:
Rebooting...
Cleaning up...
Restoring tmp...
Removing files...
Rebooting...
Are they? (y/n): n
Joseph Myers
3
Well, I took it into the Verizon store and convinced them I needed a new phone. It took almost four hours, but I think it was worth it. I may try flashing CM again once Android 4.2 is stable.
cloudsofmana
