Who can help me out please on this one :
- Thunderbolt Rooted
- Das Bamf Sense R5 installed
- Installed Titanium backup and Busybox update through Tit Backup
- Screwed with Speedtweak in console and set to 1.4 ghz underclocked.
So , system locked up after tweak, then I pulled batt. Rebooted and TB keeps rebooting. Will delete cache in NANDROID but when doing full wipe, then reboots again. Pulled batt once more, then restarted Hboot again, went to Nandroid recovery mode , selected zip file for recovering RC5. I starts the reco process but then while checking zip file/unzipping, TB reboots again. It is as if the speedtweak has changed the speed/voltage permanently at boot.
Could this be the case and if so how can I fix this ??
Thanks in advance
Thanks in advance
