Hello. Ok putting this in a time line might make it easiest to explain.
I was running ICS 246 rooted. Installed Voodoo OTA root keeper saved root took OTA update and remained rooted. I installed Safestrap and installed Liquid rom. All was well for about a week. No issues going back and forth between Liquid and stock slot. Tonight I went back to Stock and decided to stay with that for now. (no problems with Liquid by the way great ROM) Started using Stock and was sluggish and buggy. Same issues I always have after an update. I then backed everything up. Performed a factory reset and all went well. Finished and still had all root privileges. Half way through restoring apps only not system data they began failing. I stopped the restore and rebooted. After rebooting I no longer had full root. Voodoo showed device rooted but not root permissions granted. ROM tool box and TB no longer worked. I rebooted into Safestrap and applied a Nandroid back up of my stock slot. Restored but now it will not boot up. Safestrap screen comes up then the "M" and then nothing. You can hear the Bionic boot animation sound but no screen. It stays like that and then the boot animation sound again no picture. Battery pull boot back into Safestrap and activate slot 3 and reboot Liquid rom. That boots up with no problems and while in that ROM I have full root in root checker and Voodoo. I attempted a restore to a prior backup for stock slot with same outcome. I then performed a factory reset via Safestrap and then through Recovery. Same outcome. I have a working phone but only in Liquid stock slot 3. Any suggestions? I am dead in the water. Sorry for the long post.
Thanks for the help.
