Results 1 to 7 of 7
    Default Incoming call volume
    How do i adjust the volume of the incoming call. It is set at a low volume and I would like the person calling to be louder.
  2. #2
    FrankXS's Avatar
    Posts
    Global Posts
    3,645 Global Posts
    ROM
    Latest OTA Official ROM
    Default Re: Incoming call volume
    Quote Originally Posted by blockhead1961 View Post
    The only way on the native ThunderBolt to set your in-call volume is during a call. You can call your voicemail and set it then. Afterward it should maintain that setting.
    The TBolt has an issue where sometimes it forgets the in-call volume and the volume automatcially sets itself to max (or min). I have solved this with two programs from Google Play.
    One: Volume Locker. . This locks the in-call volume to a default that you set, but allows you to change it duing a call if you need to. Then it reverts back to the default after you hang up. It also locks other volumes on the phone if you like. I only use it for in-call volume becuase that's the only trouble I have with volume.
    Two: Volume Control. . This sets the in-call volume to the default that you like without having to be in a call. It also sets other volumes on your phone, if you like.
    I recommend both of the above used in conjunction with the ThunderBolt.
    -Frank
    [HTC Thunderbolt™ 4G/LTE!]
    It's not your dream phone. It's the one after that!©
    Look here for a [VZW Coverage Map] to check your area. Select 4G before hitting [Refresh]
  3. #3
    My incoming call volume is very low and I have all the settings on high? What am I missing?
    Help, I can hardly hear what the person calling me is saying???
  4. #4
    Thanks Frank, I just downloaded them, we'll see how it goes!
    Vicki
  5. #5
    Question Re: Incoming call volume
    by chance where you messing around with hidden menus?
  6. #6
    Still not working, do I have to do something after I download them?
    Thanks,
    Vicki
  7. #7
    FrankXS's Avatar
    Posts
    Global Posts
    3,645 Global Posts
    ROM
    Default
    Quote Originally Posted by thepinkicing View Post
    Thanks,
    Vicki
    It sounds like you nay have a faulty phone. Warranty? Insurance?
    -Frank
    Sent using Tapatalk 2
