G2 won't connect to data
Notasoccerstar09
3
I tried to log into the my Verizon mobile app to check data usage and for some reason It wouldn't log in.
Now my phone won't connect. Wi-Fi works fine though. Anyone have the same problem?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,687
4,837
113
Welcome to Android Central! First things first--you're certain mobile data (3G/4G) is turned on? Go to Settings>Wireless & Networks>More>Mobile Networks, and make sure Data Enabled is checked.
Notasoccerstar09
3
Yep and i've tried toggling airplane mode as well as taking out the sim.I've seen others with the same issue after updating to kitkat (i'm a bit behind) but i haven't seen a solution.
Edit: I've also tried a soft reset
MolecularGraph
635
20
Is it possible your area is going through some sort of data upgrade? I know when my town for 4g we lost 3g for about 2 days.
Sent from my VS980 4G using AC Forums mobile app
g1303bk
