Re: Screen Timeout Keeps Resetting To 30 Seconds
Mine keeps resetting to 10 minutes & I have too many apps to figure out which one is forcing this. So an easy fix, and also prevents it from happening in the future with other apps, is to use the app Tasker. Create a Tasker profile with a task that turns your screen off at whatever time length you decide. I set up the task to "happen" (Turn my screen off at 30 seconds of inactivity) whenever an app is turned on. Then I just choose my launcher as the app, that when opened, will start the task, because obviously my launcher is always "open". This is actually even better than the stock choices in your phone settings & offers some interesting options, since you can set the time to any length you want, right down to the second. Or, if you want, you can even set the screen timeout to specific lengths depending on which app is open. For instance, I play the game Ingress, & when playing, I never want the screen to timeout, so I have a task set to not ever timeout when that app is open. I should mention, however, that to achieve this, I run 2 launchers on my phone, and I open the Ingress app from the other launcher, so the 2 screen timeout tasks don't conflict.
