Hi everyone,
I upgraded over a week ago. I've reset my phone twice since but I still have the same 3 annoying problems.
First, I can no longer use swype keyboard anymore. It comes up and works to a extent but it randomly will not insert the words I swype. I did the resets and cleared swypes cache and data. I even dl the paid version. It still does it.
Second, my ringtones first ring is low then it goes up to where I have the volume set. That doesn't bother me as much as it will ring twice then stop for approx 4 seconds then restart. Im always thinking people hung up before i could answer. I've read in this forum where turning off the extra volume when in pocket setting helped a few people. It doesn't help mine. It's a regular phone ring i dl from a big ringtone etc web site almost two years ago. Before I reinstalled it after factory reset I played it and it worked fine on my PC.
Third, I use pattern lock security. A lot of times it won't recognize my first attempt at the first line. I don't run any case with a screen protector built into it so it's my finger pressed against the phone glass.
Can't get any help on these issues on vz support page. They all seem to busy making sure to tell me that their not to blame for lollipop being pushed on the s4. Like I care, I just want my phone back. I'm available for a upgrade next month but that doesn't help me now. Also, when I choose (not them) to upgrade I don't want a broken phone for a spare.
Thanks...
Thanks...
