Results 1 to 20 of 20
- 11-26-2011, 09:08 PM
Thread Author #1
- 11-27-2011, 12:56 AM #2
Adobe Flash 11.0 (Tested & Working)
Although that is the right thread for your phone and processor in general, the question is legit. From what I've seen, the app (.apk) itself is 11.0 but the libraries you must use are 10.1 or 10.2-based, whether they are a separate download or come cooked in. They are all hacked (I think), likely by a small Asian company making sub-par tablets or something. I can't verify that either, but I first heard about Flash for older (read: armv6) devices for the MaiPad tablet.
Sent from my LG-VM701 using TapatalkOptimus Slider | Device: UP | Swype 3.26: UP | Link2SD: UP | PDANet: UP | HydroROM: UP | Flash 11: MOSTLY | ADB Shell: DOWN - 11-27-2011, 08:03 AM
Thread Author #3
- 11-29-2011, 01:02 AM #4
I'm not totally sure about that yet. Xda has a flash player that supposedly works on any ROM. And there is NOT a ROM for the Net10 Gelato yet; don't use the Slider ROM because things may break.
Trying any of the flash player apk files, however, is comparatively mundane.
Edit: I tested this app on my Wildfire; it appeared to work without any custom ROM.
Sent from my Wildfire SLast edited by primetechv2; 11-29-2011 at 02:57 AM.
Optimus Slider | Device: UP | Swype 3.26: UP | Link2SD: UP | PDANet: UP | HydroROM: UP | Flash 11: MOSTLY | ADB Shell: DOWN - 11-29-2011, 12:56 PM #5
Re: Flash Player on Rooted Optimus Q (LG-L55C) ????
really wish someone would post a link for where to find out how to root the lgl55c optimus Q everyone says they have it, but multiple searches later i just cant find it.. and no one says where.. any help with this would be appreciated. thanks
(yes i've tried google)
- 11-29-2011, 08:10 PM #6
Download the drivers that are floating around Google. Then grab the latest version of SuperOneClick. I'll add the driver link if I can find them.
www.lg-phones.org/lg-optimus-v-driver-download.html
Sent from my Optimus SliderOptimus Slider | Device: UP | Swype 3.26: UP | Link2SD: UP | PDANet: UP | HydroROM: UP | Flash 11: MOSTLY | ADB Shell: DOWN - 01-03-2012, 09:18 PM #7
- 01-21-2012, 10:11 PM #8
To all lg optimus q owners. To root. Use the driver from the v701 optimus slider from lg mobile support tool. U must download this from lg.com to obtain root use the lg esteem method. Works first shot. There you go you have root access. For a custom recovery search for the recovery. Easy to find under optimus slider threads. For a rom. Use the stalkon or hellicious rom. Seeing as they are the best.
- 01-21-2012, 10:11 PM #9
- 01-21-2012, 10:12 PM #10
- 01-29-2012, 02:25 AM #11
- 02-13-2012, 06:38 AM #12
I have tried everything and I can't get adobe flash to work on my LG Optimus Q (LGL55C)...
I have rooted the phone and I have tried to install the custom apk"s for ArmV6 processors...
I have tried 10.2, 10.3 and 11.00 all of which say they will work on ArmV6 processors and no luck..
I have installed HydroRom from team hydro and then tried to install flash and no go...
I have tried to change the permissions on the "lib" files in the data folder on the root of the phone..
In summary I have tried every "fix" I have come across and other people are saying it works for them...
Why not me????? - 03-05-2012, 08:08 AM #13
hey can you post a link to the hellicious rom along with maybe a few screen shots. i hear good thinks about this rom but i just wanna see what im getting myself into be i flash. any help will be thanked
- 03-06-2012, 02:04 AM #14
lol how are you hearing good things about a rom thats not even released...? RyanThurman92 is the creator of this rom, and has not released it.
Edit: also id argue that AreaRomQ v1.1 (though I edited it quite a bit from the released version) is by far the best rom on the q at the moment. CarrierIQ disabled, full theme, Acid animations, much much more.) - 05-08-2012, 07:40 PM #15
- 05-08-2012, 09:42 PM #16
Cool.. but I highly recommend you put AreaRomQ v1.4 on your phone not v1.1...
- 05-09-2012, 10:35 AM #17
- 05-09-2012, 10:37 AM #18
- 05-10-2012, 08:29 AM #19
I rooted by grabbin the q drivers from that mobile support tool. They're under the tracfone section. Its the lg l55c.
Sent from my LGL55C using Tapatalk - 06-04-2012, 03:17 AM #20
Reply
