I flashed with the ROM here, and it works pretty well so far. The problem with me is that I'm obsessed with battery level and I always tend to look over at the battery number on the top right since the new rom, whereas before it changed in intervals of 10 or 20. Is there a way to remove or change the battery indicator so it goes back to the default instead of numerically?
