Pulling Battery
codyahiggins
90
Is it normal for a battery pull to discharge the battery about 25%? I had to pull my battery and I was at about 80% and when I put it back in and turned on my phone it was at about 55%. Other times I've noticed the same amount of change happen after a battery pull.
This is a tagline, not a signature.
raymaane
262
That can't possibly be normal. Maybe there is problem with the indicator or even the battery
Sent from Galaxy-Note... The 2nd One!
codyahiggins
90
I have tthought about that because at first it shows its lost more than 30% then eventually goes up to what the percentage actually is. And yes custom ROM, MiRaGe's latest.
kingseanrocks
77
IV had this probably before I think it was my battery because my new battery doesn't do this
AndyOpie150
1,254
32
The kernel is part of the ROM. So it would be a ROM issue.
Probably a corruption in the ROM causing the kernel panic, hence my suggestion.
smokedog87
