So I was trying to flash an OptiS ROM on the OV. Thekraven's cm10.2 pacrom. And when I clicked the ROM to flash in CWM, It showed me ''get.prop LS_670''
and lots of other build.prop codes, and then it aborted the installation. What happened, and how can I fix it? Is it because I don't have an OptiS? And I thought OptiS ROMs can be flashed onto the OV...
Set from my SlimBean VM670
