Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By tntdroid
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    3,350 Global Posts
    ROM
    Vitreous,JellyBelly,OEM
    Default Change system fonts?
    How can I change the system fonts. Root tools by jrummy won't work. Rom toolbox won't work either. I would love to flash the Sony sketch font on my xoom. Thanks for any help.
    ***GET IN WHERE YOU FIT IN***
    Snitches get stitches
    Boneyard-D1,Dinc,dX,Gtab7",Tbolt,iPad1,Bionic,Xoom,iPad2,Charge,GNexus,SGS3,Razr Maxx,Nexus7...the list shall continue
    Living Dead-iPad3,GalaxyNexus,Razr MaxxHD
  2. #2
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    In the past on my x I just took the new font renamed the regular and bold to the main stock fonts. Using root explorer just dropped them in the font folder and rebooted. Have not tried this on the Xoom but I don't see why it wouldn't work. Rename the stock ones to. Bak so u can always delete the new ones rename the old ones and get the stock back.
    sent by CyanogenMod X
    Thanked by:
    sicario666 likes this.
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    3,350 Global Posts
    ROM
    Default Re: Change system fonts?
    TNT. Dude I missed your support while away from moto devices! That worked like a charm. Its funny how simple things are on the android os. Most of the time things hide in plain sight.
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    3,350 Global Posts
    ROM
    TNT. Any idea how to increase system volume for UI interactions? Lock screen and keyboard
  5. #5
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    I have not looked into it. Never did it on any device.
