1. jojoe42's Avatar
    Now I know this is a preview and things aren't quite finished yet, but ever since 2 weeks after installing Preview 3, Android System and Android OS are always on top of my battery usage. After restarting and clearing the caches, these two are usually lower down and battery life is MUCH better for a day, and then it goes back to the way it was. Thoughts?
    06-22-2016 08:09 AM
  2. DamianP's Avatar
    I'm getting the same thing on my Nexus 6P.
    06-25-2016 12:07 PM
  3. Vikas Dhar's Avatar
    My new Glaxy s7 has been on for 2 hours and its battery is down from 100% to 55%. I switched to this from the S4 because I wanted 24 hours of battery life. At this rate, I may get 4 hours out of it. I Hope.......
    07-14-2016 05:13 AM
  4. Trigati's Avatar
    You were able to get the N preview on your S7? Are you rooted?
    Sent via the Communications Center of the Trigati
    07-17-2016 09:44 AM
  5. ptkelly's Avatar
    My Nexus 5x with beta 3 and beta 4 is doing fine. My phone has been on for nine hours and my battery registers 86% with my biggest power user being the screen.
    07-17-2016 01:00 PM
  6. JGLdn's Avatar
    Looks like Android N may be worse for battery performance than Android M, and that's pretty bad. This is the exact reason I no longer get excited about Android OS updates. Marshmallow has some neat features, but I'd go back to Lollipop just to have my battery performance back.
    mwake4goten likes this.
    07-18-2016 04:15 AM
  7. booboolala2000's Avatar
    I don't know about that. Signal seems to be better for me. On Fi, but so far the doze feature seems to be spot on.
    Attached Thumbnails Android System/Android OS battery usage?-30334.jpg
    07-23-2016 01:14 AM
  8. Yosef Elgart's Avatar
    i think first layer of Nougat doze not kicks in developers preview if you checking phone evry few minutes
    i also noticed that grennefy agrasive doze not working
    07-23-2016 03:22 AM
  9. eric002's Avatar
    Actually I thought the extreme doze feature started working within a minute or so after the phones screen was turned off. It saves enormous amounts of battery power!
    07-25-2016 04:15 PM
  10. NucleBAH's Avatar
    I don't think I'd say that. Only my old Moto G3 I'd get 2.5 hours SOT but after MM I'd get like 4. I'm on a G⁴ Plus now because my G3 killed itself but you win woke you lose some
    Posted with a Moto G⁴ Plus
    08-10-2016 08:58 AM
  11. Markxmlx's Avatar
    If you don't give the phone the time to enable Doze (it doesn't kick in instantly) then standby time will be just as bad as when Doze didn't exist. If you're someone who obsessively checks their phone (nothing to be ashamed about, even I do it sometimes) then your standby time won't be too great.
    08-20-2016 04:03 PM
  12. mwake4goten's Avatar
    HTC messed up lollipop for one m8 I still want to go back to KitKat lol even though Marshmallow is ok...
    08-20-2016 10:11 PM
  13. Vivaxha's Avatar
    I thought they were gonna fix the battery drain with the new Nougat, but it seems it's still there. Android System usage sometimes hits 82% at my Lollipop, it's at least about 15% here, still at the top, tho..
    08-21-2016 03:25 AM
  14. Ev0d3vil's Avatar
    Android OS is still draining like crazy. I'm starting to think this is a server side issue with Google.
    08-21-2016 04:59 AM
  15. JGLdn's Avatar
    KitKat worked perfectly.
    08-21-2016 05:04 AM
  16. LeoRex's Avatar
    Blame your OEM, not Android. I had a nexus 6, and N (early builds) did better than M, which in turn did better than L... Both my 5X and 6P slow marked improvement in battery consumption on DP5 over the current M builds.... Mostly due to modest idle drain improvements with the updated Doze.
    As for the issues here, every phone runs under different conditions so I can't really come to any conclusion. But I'm not seeing the drain problems on either phone I have running N, so I can only assume there's something going on specific to these phones/usage.
    08-21-2016 08:15 AM
  17. JGLdn's Avatar
    Android or OEM is irrelevant! If an upgrade causes issues that's all you look at. Every manufacturers OEM is different and that's the issue that they don't all gel well when it comes to Android updates. Hence why my next Android will probably be stock.
    08-23-2016 04:33 PM
  18. badelhas's Avatar
    Mine too. I have a HTC one M8 and love it but if the next nexus is as good had the Nexus 6P I'm getting it. I just don't like screens bigger than 5 inch. Will we have a option with a smaller screen again?
    Cheers
    08-23-2016 04:39 PM
  19. pwtuxer's Avatar
    Have you tried disabling animations?
    I just upgraded a few days ago from Marshmallow, and have had battery life problems, with what seems like unusually high battery usage by Android System and Android OS -- about 2/3 as bad as the OP reports, and enough to make it difficult to get through a full day on one battery charge.
    First I tried the suggestions of disabling Ambient Display and Adaptive Brightness, and revoking Body Sensor permissions from Google Play services as I found suggested elsewhere, and still had trouble.
    I tried clearing the cache (both the easy steps in Settings > Storage and clearing the partition from the device Recovery mode), but still had trouble.
    Last night I disabled animations (enabled Developer Mode, changed all the animation scale settings to No Animations). With Ambient Display and Adaptive Brightness still disabled, it looks like I have much lower battery drain now. It's too early to declare victory, but I am finally encouraged that Nougat might fare better than Marshmallow. It's a bit of a shame, as the OS feels more harsh with no animations, but I can live with this. I hope I'll be able to re-enable Adaptive Brightness, as I do miss that when using my phone outdoors.
    -Peter
    09-07-2016 12:58 PM
  20. puch96's Avatar
    Interesting find I saw with my 6p running N7.0. After some time after the update, I started noticing wake-lock as the awake bar was solid on. As I heard on other forums, I turned Bluetooth off, and magically the phone started Dozing correctly. So it seems that there may be something going on with Bluetooth an Android OS / System that is causing battery drain, at least on my phone.... It's a bummer because I use a smartwatch, so I have to keep an eye on it to make sure it doesn't go into the wake-lock again. But a simple toggle of Bluetooth OFF/ON seems to have fixed it for now.......
    jayhay312 and tonyr6 like this.
    09-08-2016 08:25 AM
  1. Which is the best Privacy App for Android smartphones?
    By AC Question in forum Android Apps
    Last Post: 07-17-2016, 07:08 PM
  2. Android Tablets with Wireless Charging Capability?
    By AC Question in forum More Android Goodness
    Last Post: 06-22-2016, 07:49 AM
  3. Replies: 1
    Last Post: 06-22-2016, 04:55 AM
  4. Replies: 1
    Last Post: 06-22-2016, 04:32 AM
  5. Replies: 0
    Last Post: 06-22-2016, 04:28 AM
