A
Android Central Question
I wanted to disable the multi-user feature in Android in my both Motorola phones, one has Android 5.1 and other has Android 7. I have been successful in Android 5.1 phone through the CMD command using ADB tools, the command I ran is this to disable it:
db shell settings put global guest_user_enabled 0
And the result is this that the user icon under the notification swipe on the top right does not work now it does not do anything when tapped.
Now the same command I am running in my Android 7 phone is not working and the user panel is same as it is, this is where I need your help, what wrong am I doing or is there any change in the command that is need to be done. I just want it disabled like in Android 5.1.
