A
Android Central Question
My phone started constantly rebooting by itself until it completely stopped turning on and was stuck on the logo screen. I’ve went ahead and tried repairing it and they said that the battery was the problem. So I got it replace it started working fine for about 2 weeks and then started doing the same thing. I went back and they said that the battery was loose and then tightened it. When I got home the same problem started again it keeps on turning off and only turns on when it is plugged in and this is sometimes. It turns off like how a old tv would power off.
What would be the problem?
